I have a 200 exp. with 4x4 problems. My suv is stuck in 4x4 low. there seems to be no power to the dash switch. would that indicate that the mode is nfg or could it still be the transfer case motor?? please help..
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
I'm sure you've tried already but have you spent some time going into reverse and back to drive on the dirt? When I first bought our '99 4x4 it would stick in 4low occasionally and found that going from reverse to drive a few times would clear it up.
