Temperature gauge
Old Jan 18, 2005 | 11:22 AM
97RangerV6's Avatar
97RangerV6
Temperature gauge
My temperature gauge on 97 Ranger 4.0 doesn't seem to work correctly. It moves only slightly when the truck is heated up as if it is still cold.
Thanks in advance!
Old Jan 18, 2005 | 01:27 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Provided that the engine is really reaching the correct operating temperture (195 F), then most likely it's the sending unit for the temp gauge. The 4.0 seems to be hard on senders; I've been through about four in the last 10 years. When I replace the sender, I like to use this as a opportunity to replace the thermostat too.
Old Jan 18, 2005 | 02:05 PM
AlfredB1979's Avatar
AlfredB1979
I have nothing against changing the t-stat right now either, but if you have to prioritize, take a feel at the radiator hoses. If they are hot after a few minutes of running the truck, change the sender.
Mine was quite lifeless, too, but now after changing it out, it actually goes past the first \ a decent bit. Fair enough for me this time of year.
Old Jan 19, 2005 | 11:50 AM
97RangerV6's Avatar
97RangerV6
Where is the sending unit located on the 4.0?
Thanks in advance!
Old Jan 19, 2005 | 01:59 PM
CowboyBilly9Mile
Unless something changed, it's on the top of the intake and very close to the thermostat housing. Make sure it's the sender with just one wire; if you find one with two wires somewhere that's the temp sender for the EEC system.
Old Jan 22, 2005 | 09:27 AM
97RangerV6's Avatar
97RangerV6
Any techniques on testing the sensor?
Old Jan 22, 2005 | 10:09 AM
Ford Tradesman's Avatar
Ford Tradesman
No, but put it on defrost and feel it when fully warm. Does it feel hot? Many enthusiasts feel as though heat is an enemy, and install a 180f thermostat.
Feel it.
Old Jan 22, 2005 | 11:44 AM
Dave257's Avatar
Dave257
Do not put a 180 deg thermostat in the truck unless it came with one. Use the 195 if thats what it calls for or it will kill you gas mileage.
Dave
Old Jan 22, 2005 | 12:22 PM
norcalcapri's Avatar
norcalcapri
my 93 ranger with a 2.3 does the exact same thing, never even made it to the n in normal. but i checked the engine coolant temp sender (different location than the gauge sensor) and it was pulling the correct resistance for about 192. i would try replacing the gauge itself if it bothers you, fords are known to have problems with some of their gauges, especially the termperature ones. hope this helps.
-tony
Old Jan 24, 2005 | 07:32 AM
97RangerV6's Avatar
97RangerV6
Went to get the part and there was two listed. One had a plug type connecter and the other was just and single wire connection. Any idea which one, I will check once it gets warmer!
Old Jan 24, 2005 | 07:52 PM
Ken00's Avatar
Ken00
The temp sendor for the gauge should have one wire, the ECT (PCM) has two wires.
paker
1997 - 2003 F150
Oct 10, 2011 08:15 PM
Kez
Nov 19, 2008 05:48 AM
fawey1
Nov 22, 2007 10:01 AM
sledneck97
1997 - 2003 F150
Jun 9, 2007 12:56 PM
mantta
18
Jan 3, 2006 12:02 AM
