Sponsored by: Real Truck
Help-03 SD not Starting
Old Jan 18, 2005 | 06:12 PM
Fred H's Avatar
Fred H
Guys, I need your ideas. Truck is a 03 F-250 4x4 with the 5.4 V-8 gas and 6-speed tran. I got it new 2 years ago in March and the truck has 13,000 mi. As you can I am not driving it a lot for the time being.
Truck has been sitting for about 3 weeks. Over the weekend I drove it about 200 mi. No problems. Last night I parked it and about 24 hrs. later (just a little while ago) I got in the truck and it would not turn over. I made sure that the clutch pedal was all the way to the floor and tried again. After 5-6 tries, the motor turned over. I did here a "clicking" sound actually more of a 'click' each time I hit the switch, Lights were bright, however.
I don't think my battery is weak, Temps were single digits last night, mid 20's today, Oil is fresh -Motorcraft 5w20.
My first thoughts are that either the starter appendix or the clutch neutral switch (or what actuates the neutral switch) is sticking from the cold temps or from sitting so long.
Anybody else experienced this? Truck has never done this before. As Always your comments are appreciated-Thanks-Fred
Old Jan 18, 2005 | 06:52 PM
FortyFords's Avatar
FortyFords
Clean the battery terminals ,could be starter has moisture in it .
99 had that happen croded all internal parts.
I'd chk the battery for bad cell also.
Don't rule out ignition switch also
Rich
