1978 - 1996 Big Bronco
Still having engine troubles. Engine won't turn over.
Old Jan 18, 2005 | 06:08 PM
mustanginca's Avatar
mustanginca
I pulled the alternator out and had it tested and they said it was still good. I am getting plenty of gas but no spark. I have replaced the ignition module, coil, and am open for more suggestions. I drove it for a day parked it and went to start it the next day and it just wouldn't turn over. I had taken it to the muffler shop and got a new catalytic converter. It's a 1982 with a 1985 351w I've tried everything I can think of and the Haynes books are no help.
Old Jan 18, 2005 | 06:46 PM
Capone's Avatar
Capone
I had this very same problem.....if all the units you described are in good working order...check the ground straps that connect the engine to the chassis/body.
There is one in front of the passenger side motormount. There is another that connects to the firewall on passenger side. There is one more that connects the starter to the frame next to the passenger side suspension (front))
remove, brush clean and reattach coating with a bit of ATF to keep corrosion off.
faulty grounds will do this.
ALso remove the starter cables clean the starter terminals and make sure to check the cables to see if they are still good.
Also check the Ign switch lead that goes into the starter....this was also hanging on by a thread when i found it.
Old Jan 18, 2005 | 11:23 PM
mustanginca
thanks I didn't even think about it being a ground problem. I'll try that.
Old Jan 18, 2005 | 11:36 PM
mustanginca
well I think I worded it wrong it will turn over but I have no spark. I smell fuel and have even poured laquer thinner down the carb and got nothing.
Old Jan 19, 2005 | 09:25 AM
DcSkater602's Avatar
DcSkater602
a buddy of mine had this same problem. Turns out the brand new spark plugs he had were shot from factory. Check the plugs. Check the gapping. Are you getting a click from the starter?
Old Jan 19, 2005 | 09:26 AM
DcSkater602
nevermind about the clikc i see it turns over. If there is no spark it has to be somewhere in the coil distributor plugs or wires.
good luck
recheck everything
Luggy
Sep 12, 2013 11:00 AM
jhaas63
Jul 29, 2013 04:02 AM
Abngoat
1983 - 2012 Ranger & B-Series
15
Jan 17, 2008 07:09 PM
sosuok
May 31, 2007 08:55 PM
jpt42
Electrical Systems/Wiring
15
Dec 8, 2002 10:58 AM
