1978 - 1996 Big Bronco
a/c clutch
Old Jan 13, 2005 | 11:54 AM
hotplater's Avatar
hotplater
Exclamation a/c clutch
i replaced the a/c clutch.
the magnet is only intermittenly engaging.
can't figure out problem.
maybe i need a freon boost can't see how that would affect the clutch though.
i tried the differant shims supplied.it did the same thing.maybe my compressor spline is messed up from my bearing going bad.
please help ty.
Old Jan 13, 2005 | 07:46 PM
greystreak92's Avatar
greystreak92
You may indeed need a refrigerant recharge. If the pressure in the system is too low there is a switch in the compressor that will disengage the clutch to prevent damage to the compressor.
Old Jan 19, 2005 | 09:58 AM
hotplater's Avatar
hotplater
Smile a/c clutch
thank you gray, i have found out whaT YOU TOLD ME IS TRUE .
I MUST HAVE BURNED OUT THE FREON/OIL IN THE SYSTEM.the bearing went out on me on a long trip.
