Sponsored by: Auxito
Outside air temp readout problems
Old Jan 18, 2005 | 04:52 PM
plugnickle's Avatar
plugnickle
The outside air temp readout is malfunctioning and always reads -40 f, on my 2000 F150 Scab. Would anyone that has tracked this problem down mind sharing the solution or have advice on what may be causing this problem? There is a wire that runs along the driver's side fender that has a bare connector on the end. I asked the local Ford shop manager what the connector should connect to, but he didn't have any suggestions. I am wondering if the temprature sensor is missing from this wire.
Steve
Old Jan 18, 2005 | 05:41 PM
triton_2002's Avatar
triton_2002
The sensor should be in front of the radiator under the plastic cover.
http://www.motorcraft.com/products.a...=27&PageID=422
Old Jan 19, 2005 | 02:05 PM
plugnickle's Avatar
plugnickle
Triton_2002,
I believe found the sensor that you refer to. Just so that I understand correctly, the cpu and the roof console temp display get their information from that same source?
Thank you,
Steve
Old Jan 19, 2005 | 08:11 PM
triton_2002
No, the outside temp sensor is just for the temp reading on the overhead console. The engine computer gets air temp from the intake air temp (IAT) sensor in the intake tube. Is this what you were asking? Not sure I understood your question.
Old Jan 19, 2005 | 09:46 PM
plugnickle's Avatar
plugnickle
Yes, that is what I was asking. I appreciate the answers.
Steve
DaveCinIN
Jun 9, 2013 08:30 PM
sbegley28
Sep 27, 2011 09:12 PM
bigwiege
2004 - 2008 F150
Jan 31, 2011 07:07 PM
nurse47557
1997 - 2003 F150
Jan 15, 2005 10:02 PM
billybubba
1997 - 2003 F150
Jan 11, 2005 05:29 PM
