Sponsored by: Auxito
brake light problem
Old Jan 18, 2005 | 11:48 AM
barryetling's Avatar
barryetling
brake light problem
hey guys here is the problem im having, i have a 95 ford f150 supercab 5.8litre which is constantly blowing the brake light fuse and the turn signal fuse i checked all the wiring and it appears fine also the rear sockets appear fine i am at the end of my rope could it be the multi function switch? also the rear cab light does not work.
Old Jan 18, 2005 | 12:29 PM
BillyBob69's Avatar
BillyBob69
Sounds like a short to ground on the Brake/turn wiring. Start back at the sockets and check the wiring to see if it has rubbed anywhere that would cause it to short out. Or a pinch that would cross wires.
Old Jan 18, 2005 | 06:54 PM
y2klarry's Avatar
y2klarry
The wiring that goes to the high mount brake light is notorious for rotting through under the door sill.
Stroker 6.0 fan
Oct 25, 2013 04:20 PM
Stroker 6.0 fan
Sep 6, 2013 11:07 PM
daddy dawg
1997 - 2003 F150
Dec 2, 2012 09:46 PM
daddy dawg
Apr 1, 2011 08:19 AM
speedcat
19
Sep 3, 2007 12:03 AM
