Sponsored by: Auxito
Driveline question...
Old Jan 18, 2005 | 11:15 AM
Wizardvette's Avatar
Wizardvette
Truck...1997 F150 4.6 4x4 120k.
symptom...I put truck in drive and for 2/3 feet all is good then I feel something. It makes no noise, but it feels like something grabs. It soesn't feel like it slipped first, I just feel a second "grab". It's hard to describe, but is there some "play" somewhere? Any known issues? Thanks.
Old Jan 18, 2005 | 12:55 PM
BillyBob69's Avatar
BillyBob69
That is more than likely just the front drive line engaging. If all you feel is it grabbing then it goes fine, dont worry about it. Only when you start getting clunks and grinds is when you have a prob.
Old Jan 18, 2005 | 04:34 PM
MBDiagMan's Avatar
MBDiagMan
Is the truck in 4WD when this occurs?
Good luck,
Doc
Old Jan 18, 2005 | 06:08 PM
Wizardvette
2 wheel drive. I never paid attention in 4 wheel. If I'm in 4wd, I usually have other things going on to keep me occupied. I'll try to notice next time.
Old Jan 18, 2005 | 06:21 PM
MBDiagMan's Avatar
MBDiagMan
It could be almost anything. The only way to know is to get the rear wheels off the ground safely and start checking for slack.
I have had automatic transmissions doing something like you describe. There could be some sort of problem in the transmission, if it is an automagic that causes the clutches to drop in late.
Good luck,
Doc
Old Jan 18, 2005 | 08:42 PM
Racerguy's Avatar
Racerguy
It could also be the slip yoke on the rear driveshaft binding on the output shaft of the transfer case. Remove the rear shaft and lube the inside of the yoke with (preferably) Teflon grease from your dealer or some other good quality grease and see if that helps.
Old Jan 19, 2005 | 05:36 AM
Wizardvette
It feels as though it is definately in the rear of the truck. It doesn't feel right under me. I'll check it out as soon as weather gets a bit better. It's been 0 to 6 degrees here for a few days. Thanks guys.
Old Jan 19, 2005 | 09:17 AM
BillyBob69's Avatar
BillyBob69
AHHHHHh 2 WD is when it happens. My bad....thought it was when you went into 4wd. Just an FYI...there was a TSB on our trucks that was meant to get rid of shudder when slowing and accelerating and a slight "tug" when accelerating from a stop. It says to clean the slip joint on the drive line and lube with SILCONE gease. Guess the normal stuff isnt good enough.
Old Jan 19, 2005 | 11:13 AM
Wizardvette
That's the perfect way to describe it. A slight tug with no noise, when taking off from a stop. Thanks.
Old Jan 19, 2005 | 08:05 PM
Wizardvette
OK. drove home in snow. I paid attention to any possible "tugging". It was fine. Back into 2wd, and the tugging re-appears. Still simply a lubrication issue?
Old Jan 20, 2005 | 08:24 AM
BillyBob69's Avatar
BillyBob69
Very well could be. Cheap fix. If not the issue then very little lost.
Old Jan 20, 2005 | 02:46 PM
karenj's Avatar
karenj
My truck did the same thing, dropped driveline and lubed slip yoke with Ford teflon grease. Tug went away, but re- apeared after a couple of weeks. I am wondering if the slip yoke needs to be a few thousands tighter???? This seems to be an on going issue with alot of these ford trucks.Is there a better fix than adding grease every two weeks or so???? or is this "NORMAL"??? Is it ok for that TUG to be there? But overall when the grease is added, the truck sure does take off better from a stop. Rich
Old Jan 20, 2005 | 02:54 PM
BillyBob69's Avatar
BillyBob69
You mentioned Teflon grease....the TSB that I saw said Silicone. Don't know if that would make a big diff.
Old Jan 20, 2005 | 10:47 PM
karenj's Avatar
karenj
Ford part #D2AZ-19590-A Lubricant- Teflon Grease
