Sponsored by: Auxito
need to save money
Old Jan 18, 2005 | 09:51 PM
onerockinguy's Avatar
onerockinguy
need to save money
i have a 97 f150 4.2 v6 with 120,000 and i have a #6 cylinder misfire and a clogged erg(?) valve. Ive checked spark plugs and cleaned the valve but problems presist. My truck also shakes and dies on inclines while stopped. Are these related and any advice?
Old Jan 19, 2005 | 07:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 20, 2005 | 05:00 PM
onerockinguy
can anyone help?
Old Jan 20, 2005 | 06:24 PM
Steina's Avatar
Steina
CO River Rat
Try posting in the 4.2 Forum - hopefully you'll get some hits!
Steve
Old Jan 20, 2005 | 07:10 PM
MBDiagMan's Avatar
MBDiagMan
I think you need to start with a compression check or leakdown test to determine the health of that cylinder.
Best of luck,
Doc
ASE Master
Old Jan 20, 2005 | 07:25 PM
Hecklerboy's Avatar
Hecklerboy
Check the EGR valve again...
On some truck (like my old S-10) once the EGR valve goes it's impossible to clean it. You have to buy a new one. I'm not sure if this is true with Fords (I'm a new Ford owner), but it might be something to ask about.
Old Jan 20, 2005 | 11:40 PM
LxMan1's Avatar
LxMan1
Could just be a bad EGR sensor triping the light. Did you replace the wires too? Could also be a bad coilpack. My Windstar lost 1 cylinder from the coilpack. It can be checked with an ohm meter.
