1978 - 1996 Big Bronco
help with a clunk or thump...
Old Jan 18, 2005 | 08:09 AM
94F150Shorty's Avatar
94F150Shorty
hey guys...
my 96 bronco just started a clunk or thump when i turn right. it doesnt do it when i turn left. it sounds like its coming from the rear but i really doubt it. it only makes one sound though. not a clunk..clunk..clunk. i hope someone has had this problem and can help...thanks in advance
Old Jan 18, 2005 | 08:50 AM
BillyBob69's Avatar
BillyBob69
Check your leaf spring U bolts, bushings, shims...etc. Make sure all is tight and not cracked broken or anything else.
Front end, usually ball joints or tie rod ends. Raise the wheel of the ground and grab it at the top and bottom and see if you can move it. You can tell if it does move abnormally. Thats for the ball joints. Have a friend watch the tie rod ends as you crank the wheel back and forth with it on the ground. If they visibly move well before the wheel moves, replace em. Also check the shock and coil spring mounting bolts. Make sure they are tight.
If all that passes, then you may be looking a drive train parts. But the easy stuff first.
Old Jan 18, 2005 | 06:49 PM
Capone's Avatar
Capone
also check the large radius arm bushings....being that the passenger side is next to the cat converter it is exposed to heat and such and won't last as long as the driver side....replace both at the same time.
cheers
