Timing/Overheating
Old Sep 10, 2002 | 07:12 PM
JTed111's Avatar
JTed111
Timing/Overheating
85 F-150, 5.0 EFI, TFI Ignition
Hot stalling, intermittent starting when hot, bad spark knock. Had a shop replace the TFI module and it appeared to have fixed the problem, for about thirty miles. Started running very hot again.
I have replaced plugs, wires, cap/rotor, battery, cables, thermostat, radiator cap, checked the water pump, fan, and flushed the coolant. I checked the timing and found it to be about 15 BTDC-- spec calls for 10 BTDC. Corrected the timing and it runs as bad or worse-- same symptoms. It idles fine with the SPOUT unplugged, but seems to trip up when I hook it back up. I know that unhooking the SPOUT bypasses the EEC, so that makes sense.
Appears to be getting sufficient spark and charging system is working. No known problems with fuel system.
I have read many of the posts regarding bad TFI's. Could mine have gone bad already? If so, is there a contributing factor or just lucky enough to get a bad part? Could the PIP or EEC/PCM be bad? How do I check?
I have very limited tools and no testing equipment other than a multimeter, and I am not excited about testing all the wires or pins in the module(s).
Thanks,
JT
Old Sep 10, 2002 | 09:01 PM
Franklin2's Avatar
Franklin2
Timing/Overheating
[updated:LAST EDITED ON 10-Sep-02 AT 10:04 PM (EST)]The computer may be able to tell you whats wrong. Get a cheap code reader and see if it sees anything wrong like a bad sensor or something.
Old Sep 10, 2002 | 09:14 PM
Franklin2's Avatar
Franklin2
Timing/Overheating
snyder661
1978 - 1996 Big Bronco
13
Jun 8, 2010 05:35 PM
mxhowes1
Mar 3, 2008 10:05 PM
scott36
New Member Introductions
Jan 16, 2008 06:46 AM
shoot
90
Jul 27, 2004 09:57 AM
mebe2k
1983 - 2012 Ranger & B-Series
Mar 21, 2004 07:42 PM
