Does anyone know a good source for Early Bronco Windshields? Just bought a sweet engineless 1970 Sport V8 model with no rust in boxwood green. First one I've seen with good floor pans, rockers and inner fenders- a keeper for sure. Want to make it into a half-cab. It's had a ps conversion done, canned ham pump and box are there but no mounts.
I have another "donor" Nebraska Plow mule with a running 302 engine that I plan to freshen and put in.
Also, I need the linkage that bolts to the manifold and connects the firewall linkage to the carburetor linkage. Is this a common ford piece? Where can I get one?
I've never had to find a windscreen for my Bronco. Maybe try Windshields America or PPG? Broncos use flat glass, so if all else fails, you should be able to cut a piece from a sheet of flat tempered, laminated safety glass .
Should be able to get a windshield from any automotive glass shop or from any of the Bronco suppliers that So Cal Desert Rider recommended.
Do you need the mounts for the pump to engine mounting? You can get them from the Bronco parts suppliers as well.
Same thing for the carb linkage. You can get a linkage that goes directly from the throttle bellcrank to the carb from any of the above Bronco suppliers.
Thanks for the info. Up to now, I've haven't looked at the catalogs much- I'm afraid I will be tempted to make it look good instead of making it run good. Thanks for the windshield info.
check out this web site, my glass was 105.00 and they set it up so I could pick it up at a local shop. excellant service http://www.windshieldstogo.com/
