05 Auxiliary Switches
Old Jan 17, 2005 | 07:48 PM
Monster Duty's Avatar
Monster Duty
Just wondering if anyone has purchased the auxiliary switches that are available for the 05 SD . (switches only I don't need the brake controller)
I have a 04 and these switches would work great with aftermarket driving lights .
Any thoughts or suggestions ???
TIA
Old Jan 17, 2005 | 07:56 PM
Fieldday's Avatar
Fieldday
Yes I did. But the owners manual does not mention them at all.
It tells were the fuses are in the fuse box. They are fused seperatly at 10 amps.
But the manual fails to mention anything else about them...
No clue how to even access them. Huge liabilty on Fords part...
Someone hooks up a refigerator to a switch and burns the truck to cinders and whose fault is it???
Old Jan 17, 2005 | 08:32 PM
Monster Duty
Do you have a 05 ?
If not do you have a part number for the switches ?
The dealer that I deal with told me that these are not available for purchase at this time .
Thanks...
Old Jan 18, 2005 | 06:55 PM
Fieldday's Avatar
Fieldday
05 sorry...
Old Jan 18, 2005 | 07:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Try this for wiring
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
Old Jan 18, 2005 | 07:36 PM
gcon's Avatar
gcon
I have an 05 F-350 with the outfitter switches. You will find the wires behind the fuse panel. They are four wires bundled together and labeled 1 through 4. switches 1 and 2 are 30 amp fused, 3 and 4 are 10 amp fused.
Old Jan 18, 2005 | 07:52 PM
IB Tim's Avatar
IB Tim
The link above has pictures and ..
Old Jan 19, 2005 | 12:41 AM
tbirdrick's Avatar
tbirdrick
I'm drawing a blank.....
Aside from driving lights, and maybe a winch...neither of which I need, what else might you run from those switches.
I got them, just on spec., always like to be prepared.
Rick
Old Jan 19, 2005 | 06:56 AM
IB Tim's Avatar
IB Tim
I am hoping a real smart member of FTE can tell me how in detailed instructions to hook up my trailer lights to one of the SW's, so I can blink them after passing....you know how it is nice to thank folks when driving at night.. The other thing I want to do is hook up the back up lights to the one of the SW, so with key in Acc position I can turn the back-ups on, or while driving forward, turn them on.
Now you all know I am the WORST person for electrical things....can shock myself with a AA battery. That is why I need great instructions....with pictures if possible!
Old Jan 19, 2005 | 01:47 PM
Tuggingafiver's Avatar
Tuggingafiver
running switch #4 to my electric fuel pump to transfer diesel from my in-bed aux tank to the main tank,,
switch #3 will soon be controlling a bright set of backup lights,,
Tim, you could locate the brake lght wire under the dash and tie it into one of the switches,, would burn them when ya flip the switch,, good idea,, I'll have to tinker with it to see what I can find under there to tie into,,
Old Jan 19, 2005 | 02:25 PM
FSeybert's Avatar
FSeybert
Upfitter switches
According to Rich Ford, in Albuquerque, NM, teh part number is 5C3Z13D730AAA, price is $39.45 for the assembly.
I plan to get them for my '05 as well.
If all your looking for is the "Thank You" flash, I simply use the Hazzard Flasher to flash a couple of times and then turn it off.
Old Jan 19, 2005 | 03:34 PM
FSeybert's Avatar
FSeybert
Additionally, Ford lists the wiring harness adapter for the switches, P.N. 5C3Z14A303AA for $18.75. My harness and switch assy. are on order from Memphis. I'll update everyone when they come in.
Old Jan 19, 2005 | 10:15 PM
Monster Duty
Thanks for the help !!!
I will be talking to the parts guy really soon .
THANKS AGAIN
Old Jan 20, 2005 | 07:02 AM
IB Tim's Avatar
IB Tim
Hi Fred did not know you are a neighbor of mine.....in Abq, I see you live pretty close to me...Welcome.
Old Jan 20, 2005 | 07:33 AM
Jerricho's Avatar
Jerricho
Does any body know if this will fit the 04's ? This looks like the perfect setup. Or at least will it fit the dash and keep the factory fit? Wiring is easy but if the factory wiring is already there, thats even better yet.
