1978 - 1996 Big Bronco
Installing left side power mirror
Old Jan 17, 2005 | 03:45 PM
DustinHoyt's Avatar
DustinHoyt
1993 Ford Bronco
The left side mirror (drivers side obviously) is busted, and it is a power mirror. We have the new mirror. Question is, how exactly do you install these? We assume that you take the door panel off. Probably not real hard to do, but would like some guidance or suggestions on how to approach installing the new mirror ourselves. Please, step by step help would be much appreciated. Please help!
Thank you.
Dustin
Old Jan 17, 2005 | 06:47 PM
Trublufords's Avatar
Trublufords
Remove door panel-pull plastic rain sheet back (try to save)-unplug wire plug(look at new to know what it looks like) and two wire retainer plastic clips tied or taped to harness(holds wire in place on door)-remove 5/16(nut size) gold bolt- now outside of truck remove two torx head screws(remember you can fold mirror in to gain access)-pull mirror out manevering center brace through center square hole in door and wire harness-reverse order BUT transfer gasket-trim from old mirror to new if not on new mirrof Good Luck!!!!
Old Jan 17, 2005 | 11:17 PM
DustinHoyt's Avatar
DustinHoyt
Thank you so much for your help! I appreciate it very much. It worked when we put new mirror on! THANKS AGAIN!!!
