Electrical quandry
Old Aug 7, 2002 | 12:49 PM
billybob1's Avatar
billybob1
Electrical quandry
Trying to solve electrical problem. Here's what I have:
--86 F150 302 2wd auto
--Battery--6mos old
--Battery cables-new
--Starter--new
--distributor--new
--coil--new
--ignition module--new
Problem: Battery does not hold charge....truck will start with jump, but after running for a while will not restart....engine cranks very slowly...and battery seems dead. I get a reading of 15volts on battery when engine running.....
thanks for any help
BZ
Old Aug 7, 2002 | 03:22 PM
brokebronco's Avatar
brokebronco
Electrical quandry
You could possibly have a bad cell in the battery. It sounds as though the alternator is charging alright, just a tad high. I've seen batteries with dead cells act like your symptoms. No garruntee but worth checking.
BROKEBRONCO
84 Bronco 351HO/C-6/208/10.25 Rear/D44TTB Soon to have D60 Front/NP435
86 F250 351HO/C6/10.25 Soon to have a front axle and the ZF tranny
Old Aug 9, 2002 | 05:31 PM
billybob1's Avatar
billybob1
Electrical quandry
You were right.....checked everything else just to make sure..then took in battery.....6 month old heavy duty battery was toast. sometimes it's the simplest thing. Battery was replaced free...I'm up and cruising again.
thanks!!
BZ
Old Sep 10, 2002 | 08:58 PM
Franklin2's Avatar
Franklin2
Electrical quandry
Old Sep 16, 2002 | 05:51 PM
brycemc's Avatar
brycemc
Electrical quandry
hello,
i have had similar problems on my 1986 ranger. i replaced the alternator and everything was fine. you can usually get that checked for free and see if that's what you need.
Old Sep 16, 2002 | 11:45 PM
electricmaniac2's Avatar
electricmaniac2
Electrical quandry
15 volts does sound a bit excessive...supposed to be 13.8 ballpark. it is possible to ruin a battery by overcharging it. I would also check the alt. and regulator (if not internally regulated).
