Sponsored by: Auxito
psi in tires???
Old Jan 17, 2005 | 07:25 AM
tscryba's Avatar
tscryba
Question psi in tires???
question... i hope an answer will match it..
i own (2003 Screw F-150 V.8 4.6L, 4x2 (completely stock)) my door panel shows to run the tires with the front being 30 PSI and the back being 35 PSI, well when i went to go get my oil changed recently the guy at city-garage said to run all of the tires at 35 so the truck is evened out with weight and all, should i leave it at 35 and 35 or set the psi to the ford recommended on the door panel???
Old Jan 17, 2005 | 07:35 AM
alcove3837's Avatar
alcove3837
I run 35 psi in all my tires unless I'm towing something, then I increase the rear tire pressure to 40 psi and leave the fronts at 35psi. Alan
Old Jan 17, 2005 | 09:42 AM
spikedog's Avatar
spikedog
What is the recommended psi listed on the tire sidewall? I'd go by that in most cases.
Also, look for any wear patterns in the tread that might indicate under- or over-inflation. The tires that came stock with my '01 were junk (General). What is on your rig?
Old Jan 17, 2005 | 09:55 AM
charlesh's Avatar
charlesh
Hi,
I have a 03 F150 XLT Scab 4.6 V8 4 X 4. The door jam / gas filler latch read 35 front / 35 rear. But I guess a V8 4 X 4 is a lot heaver.
Chip
Old Jan 17, 2005 | 10:18 AM
PaulC's Avatar
PaulC
Follow the door sticker, unless you are using tires with a different load rating than the factory tires. Ford, particularly post-Firestone+Explorer, spends a lot of time determing the best compromise between load carrying, handling and ride quality when recommending a tire pressure.
Old Jan 17, 2005 | 12:16 PM
MBDiagMan's Avatar
MBDiagMan
Yes, go with the door sticker. The pressure embossed on the tire is the MAXIMUM tire pressure, not the normal running pressure.
Good luck,
Doc
Old Jan 17, 2005 | 03:32 PM
tscryba's Avatar
tscryba
Smile hmm..
well the factory door latch says 30 front 35 in back, the tires are the stock general ameritrac 16 inch 255....
Old Jan 17, 2005 | 03:48 PM
spikedog's Avatar
spikedog
If they are the stock General rim protectors, then go with the door sticker.
