dome light
Old Jan 16, 2005 | 11:40 PM
77' f-100 ranger xlt's Avatar
Question dome light
Hey all I was wondering how to wire in the dome light. I have the wires ran, now all I need to know is how do the wires come into the light. Does it come in thru the sides, behind the bulb or what. If any one can run out to their truck and look for me that would be great.
Old Jan 17, 2005 | 12:18 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
i believe they run over the headliner and in the back of the bulb case.....
Old Jan 17, 2005 | 12:20 AM
does it go under the bulb or in one of the sides of the light case.
Old Jan 17, 2005 | 12:32 AM
SwOkcOffRoader
i just went out and looked on my 76 F-150, i popped off the cover and there werent any wires inside at all, just two long metal rungs that the light snapped into on each end, the rungs are screwed down at the ends into the corner screws that hold the whole case in place....i hope i havent lost you, i didnt take it any furthur apart but from what i can tell the wires are connected on the back side of the casing where the two rungs connect....thats my guess anyway......the bulb is a long narrow type that a little wire sticks out either end, and those are the contact points that connect to the metal rungs.........sounds just as confusing as it looked to me in the cold........
Old Jan 17, 2005 | 12:41 AM
oh no it is making perfect sense. i was thinking it connected in the back some where I just dont know where yet. But no you did no lose me or maybe i am so lost it just makes sense.
Old Jan 17, 2005 | 06:12 PM
Now I was wondering if there is a grommet to insulate the power from the cab. Does any one know the answer here.
Old Jan 19, 2005 | 07:53 PM
can anyone please go and look and get back to me on where to wire the dome light.
Old Jan 19, 2005 | 08:01 PM
Mil1ion's Avatar
Mil1ion
Do you have a cargo light as well ?
They are different when a cargo light is involved.
Just Dome light has a little flat connector for a screw to got through, this flat piece also clips into the roof part of the body then the dome light body is screwed to it.
Old Jan 19, 2005 | 08:04 PM
yes I have a cargo light.
Old Jan 19, 2005 | 10:31 PM
Mil1ion's Avatar
Mil1ion
What do you have for wires then ?
I assume you have a butchered Wiring harness
Old Jan 19, 2005 | 11:49 PM
my wiring harness is all brand new from centech. I have the wires ran to the light I just do not know where to terminate them. Do I do it on a screw on the inside of the cab or do I use insulation and do it in between the cab and the bed. Thanx for your help Mil1ion.
Old Jan 19, 2005 | 11:53 PM
wires
Oh I forgot for wires I have one that comes from the light switch and two from the doors that are spliced in. My cargo light will be wired seperately. I hope.
