window regulators
Old Jan 16, 2005 | 09:43 PM
Jerry_C1973's Avatar
Jerry_C1973
window regulators
Does anyone know where I might find a set of window regulators for my "67 F-350 ?
Old Jan 16, 2005 | 10:10 PM
ranger240's Avatar
ranger240
if it is nice tomorrow, I'll go to pull a part and see if they have any good ones
Old Jan 17, 2005 | 05:58 PM
rebocardo's Avatar
rebocardo
There are three choices:
1) used - For example, swap out a pass. window spur gear into the driver's regulator.
2) new - buy them brand new for $150-$200 per side.
3) fab - Buy 1973-1979 window regulators for $30 each, swap out some parts and with some welding you have new regulators. Search on my username and see how I welded some up. Not hard at all with a MIG welder and you do not need that much heat.
Old Jan 17, 2005 | 10:10 PM
Jerry_C1973
Thanks rebocardo. Your tip gave me just the excuse I needed to go out and buy a new welder. I have an anchient Lincoln stick, but I have been itching to get updated to a wire feed. Now I have incentive as I happen to have a matched set of 73-79 doors that came as part of the package deal for my '67. once the procedure is complete I will be giving a full report w/ pictures. again thanks.
Old Jan 18, 2005 | 07:45 PM
rebocardo's Avatar
rebocardo
You are welcome. The nice thing is once you swap over, if you ever need a gear again, all you have to do is order another regulator and swap out the gear. Yea, I do think an ARC welder might be too hot. I started off at about what I would do for 1/8 metal and ended up turning the heat and wire speed down a lot.
magicbus
1947 and Older Ford Trucks
20
Feb 12, 2018 08:33 PM
emgee
May 29, 2007 03:05 PM
PetesPonies
Jun 23, 2000 09:12 PM
