c-4 leaking at gear input shaft
Old Jan 16, 2005 | 02:31 PM
jaroh's Avatar
jaroh
Hello all, I am looking to find some parts for my c-4 transmission in my 73 bronco. Currently my gear selector shaft is leaking. I have resealed it twice and keeps on leaking. I have also heard about sleeves to put over shafts to give the shaft a smooth surface. Any company names would be helpful. Or any company names to order a new shaft from.
Thanks, Duane
Old Jan 17, 2005 | 09:51 PM
jaroh's Avatar
jaroh
Should I just go to the transmission shop?
Duane
Old Jan 19, 2005 | 11:33 PM
shaggymane's Avatar
shaggymane
Jaroh,
I know what you are looking for by the name *slip sleeve*. I've put two on (used two) for the yokes on a transfer case. Can't really give you a brand name. I went to an industrial bearing place.
Wouldn't know if the come as small as you need. You're talking about the shaft that goes thru the case right? Seems to me that you'd have to pull that shaft out to install the slip sleeve. (IIRC, it's a T bushing that butts up against the back end of the shaft)I'm guessing that can't be done with the hubs and clutch drums in place.
No wait, I'm thinking about the kick down lever. The shift lever has a nut and bracket on the inside, right? You might be onto something doable.
I'm curious how you sealed it twice. Isn't that set up a bushing and an O-ring? Maybe needs/try a thicker O-ring. Wild *** guess there. Good luck.
Old Jan 20, 2005 | 03:26 PM
jaroh's Avatar
jaroh
Shaggymane,
I appreciate your reply. I have resealed the shift lever twice. Remove the pan etc.. take the nut off the back side. The seal that goes in there is not a typical O ring. I wish it was. The reason I was asking if there was something to go on the shaft was that mine has a few pits in it. I am sure this is the cause of the leak. I think I am going to go to the transmission shop and buy a new c-4 shift lever and then swap out the arm. The arm on the car c-4 shaft does not stick out as much. I guess the welder and the dremel tool will come into play then.
I will figure something out here and reply back to you with what I come up with. Thanks again.
Duane
oleredford
Jul 31, 2014 06:33 PM
P38fighter
Jul 8, 2012 03:36 PM
thekingofcows
Offroad & 4x4
16
Mar 8, 2012 06:20 PM
82f100460
Feb 24, 2012 03:16 PM
daningraham
Nov 9, 2010 05:11 AM
