Took my carb off to rebuild it..its the carter 1bbl...the number was 7655 S..went to the autoparts store to get the kit they had 3 different ones all with different part numbers..NONE of which were 7655..anyone know what the deal is?
i had the same prob wiht my truck as well. you say its a carter. they are hard to find in sum areas, i had a motorcraft on my truck and switched to a reproduction carter. the prob i ran into was the engine wasnt the engine that was in it orig. my truck is a 1979, but the engine is a 1975...the intake manifolds had a wider spacing from 68,69 to 75, then after that they went back to small , then big again...so i dunno, this might help..id go with the idea of a rebuilders number myself. it took me 4 days to find, order the right one, after they had given me 2 wrong ones before hand...so...
Was the number stamped into the carb base, on a metal tag attached to the air horn, or cast into the body? The correct number shoudl be stamped into a metal tag. If the tag is lost I've seen many carbs with the carb # stamped into the carb body. If the number is cast into the body, and therefore is actually raised above the surrounding surface, it is not the correct #. I've had many a customer give me a carb number that was cast into the body. It's an easy mistake to make.
If your number is correct it may be that the kit manufacturer just doesn't make a kit for that particular carb. Try another supplier. In my experience Tomco seems to have better coverage on "odd" numbers than does Hygrade.
I'll take a look at my catalogs tomorrow and see if I can get you a part number for this number carb.
That would be a great help if you could find the correct number. Youre exaclty right. The number I have was cast on the carb itself. I didnt see any tag with a number on it. The only other number I did see on the carb was 8509 with a slash underneath and 5
Doug, what year truck is it? Look toward the base of the carb, down by the throttle plate. See if its stamped there. We just did the same on a guy at works carb and it was stamped there. Hose it down with carb cleaner. Crud might be covering the numbers.
Karl
OK Doug, I checked this AM and I come up with a Hygrade part # of 1220C with the corresponding float part number of FL38. It fits Ford 300 6cyl with a Carter YFA from 1981 through 1986. Shouldn't run more than $30 for the kit. Hope it helps.
Karl
I have a kit here its a Walker & the # is 15789B I got it for my 84 YFA it covers all these crbs it looks like in the IPB (backwards compatable) $14.00 Oreilley's
I really appreciate the info guys..Do you usually replace the TP sensor when you have rebuilt yours or replaced a carb?..Is there a test you can run on it to insure its giving the right feedback? Btw my truck is an 84.
