Will dodge wheels fit my Ford?
Old 01-16-2005, 09:09 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
Question Will dodge wheels fit my Ford?
A guy at work is selling a set of factory polished aluminum 8 lug wheels from a 2001 dodge truck. Would these fit my 85 F-250? He is only asking $80, I figure it would be a step up from the steelies I got now.
Old 01-16-2005, 08:15 PM
tlindemann's Avatar
tlindemann
tlindemann is offline
not shure the easiest way is to measure the spacing of the studs. take a tape measurer and measure from the center of one stud and measure to the center of the next one to it and compare to the dodge rims. Might double check the center hole for size too.
Old 01-17-2005, 12:30 AM
Kenworth's Avatar
Kenworth
Kenworth is offline
If the dodge wheels are hub pilot one word is no I think the bolt pattern should be the same.
Old 01-17-2005, 01:20 AM
SoCalDesertRider's Avatar
SoCalDesertRider
SoCalDesertRider is offline
Your Ford wheel bolt pattern is 8x6.5". The center hole on the wheels is about 4 7/8". Aftermarket wheels can be as large as 5.2" on the center hole size.
If the 2001 Dodge uses the same wheels as the earlier model Dodges with 8x6.5" bolt pattern, then yes, you can use the Dodge wheels on your Ford. The Chevy wheels of that era were the weird ones with too small a center hole size to fit either Ford or Dodge, but Ford and Dodge wheels will go on a Chevy, of the early era.
For greatest accuracy, measure accross the bolt circle, from one stud center to the opposite stud center on the other side of the circle. Should be 6.5" to work your truck. The new metric size is 170mm (on Fords anyways), which is about 6.7", so measure carefully.
Justin73supercamper
06-02-2016 10:10 PM
BlueOvalLover
03-30-2016 08:29 PM
Danbear
26
03-15-2015 04:00 PM
2006powerstroke90
04-17-2011 09:34 PM
fordinmudd
Offroad & 4x4
04-01-2011 10:54 PM
Quick Reply: Will dodge wheels fit my Ford?
