78 crewcab
Old Jan 15, 2005 | 10:48 PM
theguy_88's Avatar
theguy_88
Exclamation 78 crewcab
i have a chance to buy a 1978 FORD F-250 CREW CAB 4X4, Auto on propane, 6 inch suspension lift, many new parts but needs a few more, 38 inch TSL super swampers, body rough how much is it worth$? how bad it it to find replacement like patch panels or a cab if needs to be replaced how much would that cost?
and doors are the front doors the same as a two door truck? and the rear doors are bad how hard is it to find them for and how much$? and box is not fixible but i can find that. and where is the gas tank is their one behind the rear differantal? or is it in a different place than a regular cab has its?
Old Jan 15, 2005 | 11:07 PM
Mil1ion's Avatar
Mil1ion
The Fuel tank above the rear axle is the MAIN tank.
A 2nd aux tank would be attached along the frame behind the cab driver's side.
See this thread about putting a value on a truck.
https://www.ford-trucks.com/forums/s...d.php?t=102632
Check our sponsors for the parts you mentioned
