Hi everyone. I'm about to own a 6.0L Powerstroke for the first time. What do I need to know about being a good diesel owner? Do I plug it in every night in the winter? What is the best oil & filter? How often should I change the oil? Are there any other preventative maintenance tips I should know? How about mods? Thanks
If it gets down to 5 deg. or below you might want to consider plugging it in. there are several strings about oil changes, but just follow the owners manual. It all depends on your driving conditions. If you live a really cold part of the country you might want to go to a lighter weight oil. This is also described in the diesel suppliment manual. You will enjoy the power. Keep on truckin.
I read a thread that mentioned they thought all '05 diesels had the block warmer built in. So if I buy a truck off the lot that does not have the plug I can just buy the plug and wire it in?
That would be correct. You might want to try to just make it part of your "deal" along with a hood insulation blanket maybe? Just a thought...nothing ventured...nothing gained.
