Engine Oil Question...
Old Jan 15, 2005 | 08:34 PM
sealguy's Avatar
sealguy
I have an 89 F-350 7.3, what oil do you guys run in the engine? A guy at work told me that there is oil that is formulated for diesels. Any particular brand? Any replies are appreciated.
Old Jan 15, 2005 | 10:00 PM
PLC7.3's Avatar
PLC7.3
Shell Rotella 15-40 is for diesels, available at wallymart now...also the FL1995 filter for a powerstroke will fit, adds a qt to total oil used but better filtration.
Note 15-40 is for use between 0*F-100*F, below 0*F use 10-30.
Old Jan 16, 2005 | 12:10 AM
why165's Avatar
why165
i use mobil delvac, i used to use the rotella but i just seemed to burn it more than i do the mobil, both are good oils i just have better luck with mobil
Old Jan 16, 2005 | 06:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Mobil Delvac 1300 15W40 till I get 10,000 miles on the engine.
Then I will switch to Mobil Delvac 1 synthetic.
Old Jan 18, 2005 | 09:47 PM
89ford73's Avatar
89ford73
i run exxon xd3 40 340,000 miles and still tickin. if it gets real cold where you live, i would run a 10 or 15-30 in the winter.but for avg temp above 70, i run straight 40 weight with 2 quarts of lucas per oil change. i add straight 40 between changes.i love mobil oil also. i used to run it all the time."straight 40" till you couldn't buy it by the barrel any more. then i switched to exxon. it's good oil for me. and you wouldn't catch me dead with a quart of rotella in my truck... just a personal opinion, but i had bad luck with it. bought a barrel one time to use in my dozers, cuz they were out of anything else, made all the seals in the engine and transmission start leaking. i even had one that the pan gasket strated leaking.. try and figure that one out. never rotella again. the rotella was a straight 40 also so it wasn't a difference in viscosity. i think all the "detergents" in the oil cleaned the "seal" right outta my oil seals.
