Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
1977 Ford Bronco (Engine Stalls after overheated)
Old 01-17-2005, 06:26 AM
Coondawg1344's Avatar
Coondawg1344
Coondawg1344 is offline
I have a 1977 Ford Bronco with a 302. Recently I warmed up the Bronco in the morning waiting for the engine to lower it's idle. Unfortunatly, I went inside and when I returned 15 min later the vehicle was idling at a high RPM rate.
I drove the vehicle about 500 yards when the engine stalled like it was out of gas. I vented the radiator and loosened the gas cap. The truck started and it drove like new.
The next day, once the vehicle heated up it again stalled twice. I made it to work and then after work on the drive home it stalled every 1000 feet. I wait 3-5 minutes and it would start and then 1000 yards later it would stall again.
I was thinking it may be a fouled fuel filter but I can't get why it stalls like it is out of gas. Is there anything on the 302 that will cut of gas supply??? or is it fouled distributor?????
Old 01-17-2005, 09:25 AM
GrayRanger4x4's Avatar
GrayRanger4x4
GrayRanger4x4 is offline
First WELCOME to FTE!!!
Have you check for a blown head gasget{water in oil,oil in radiator}??You might need to add come coolent to it and find your lick if it is low.JMHO
Old 01-17-2005, 06:52 PM
Coondawg1344
Head Gasket is fine. I know it needs a new Thermostat but I didnt think that the thermostat could cause the engine to stall. I am sure it is some componant that is getting overheated, I just cant figure out what it is.
Old 01-17-2005, 06:54 PM
3broncocrazy's Avatar
3broncocrazy
3broncocrazy is offline
vapor lock? if the engine is running hot and the gas line is getting to hot.......could cause it to stall
JayBear
Modular V10 (6.8l)
05-10-2021 09:11 AM
Oil Guard Tech
04-22-2006 06:00 AM
FTE Ken
Site Announcements
10-29-2005 09:38 AM
dallasford
08-19-2005 08:04 PM
doc4bax
Oil & Lubrication
06-30-2005 03:42 PM
Quick Reply: 1977 Ford Bronco (Engine Stalls after overheated)
