1977 Ford Bronco (Engine Stalls after overheated)
I have a 1977 Ford Bronco with a 302. Recently I warmed up the Bronco in the morning waiting for the engine to lower it's idle. Unfortunatly, I went inside and when I returned 15 min later the vehicle was idling at a high RPM rate.
I drove the vehicle about 500 yards when the engine stalled like it was out of gas. I vented the radiator and loosened the gas cap. The truck started and it drove like new. The next day, once the vehicle heated up it again stalled twice. I made it to work and then after work on the drive home it stalled every 1000 feet. I wait 3-5 minutes and it would start and then 1000 yards later it would stall again. I was thinking it may be a fouled fuel filter but I can't get why it stalls like it is out of gas. Is there anything on the 302 that will cut of gas supply??? or is it fouled distributor????? |
First WELCOME to FTE!!!
Have you check for a blown head gasget{water in oil,oil in radiator}??You might need to add come coolent to it and find your lick if it is low.JMHO |
Head Gasket is fine. I know it needs a new Thermostat but I didnt think that the thermostat could cause the engine to stall. I am sure it is some componant that is getting overheated, I just cant figure out what it is.
vapor lock? if the engine is running hot and the gas line is getting to hot.......could cause it to stall
