Ok, would the roller bearing's help alot on camshaft I will be building a 410 w/ 10.5 comp stock heads ported per ford building hi po's . Would it add any or much on the build. I don't mind spending the fund's if it help's a lot.
Don
It may be useful if you have high spring pressures, but I can't imagine that there is a noticeable benefit on the street. I didn't put 'em in my engine.
I wouldnt use roller bearing for a street/strip motor.....Roller bearings are made for all out racing application's and the engine wont provide enough oil to the bearings for long lasting street use...sitting in traffic..lower rpm's....Idling at a light etc...
However you can use a roller cam with standard bearing for street application's..that will hold up very well... I'll be running Dura bond Cam bearings with my Roller cam for both duties street/strip ...
