engine dies
Old Jan 14, 2005 | 08:22 PM
tidwells 7.3's Avatar
tidwells 7.3
engine dies
I HAVE THE TRUCK ABOUT A MONTH. ON MY WAY HOME DRIVING ABOUT 30 MINUTES THE ENGINE DIES! IT STARTS THEN DRIVE A COUPLE OF MINUTES THEN DIES 3 MORE TIMES. WHEN IS STARTED THE 4TH TIME IT STAYED RUNNING BUT NOW I GET SOME KLANK OR STRONG PUFF FROM THE FRONT LEFT ONLY WHEN I TAKE MY FOOT OFF THE PEDAL AND NOT EVERYTIME. I WAS GOING TO LEAVE FOR TAHOE TONIGHT BUT NOT SURE IF THIS IS A PROBLEM OR IF IT HAS PASSED?
PLEASE HELP
Old Jan 14, 2005 | 08:27 PM
JuicedCoupe347's Avatar
JuicedCoupe347
Sounds like what was wrong with my boss's truck and it was a camshaft sensor
Old Jan 14, 2005 | 08:36 PM
lancer's Avatar
lancer
Not sure what you mean about strange klunk or puff from front left but the engine dieing could be your cam position sensor. There famous for these!!
Old Jan 14, 2005 | 08:42 PM
tidwells 7.3
Where?
THANKS FOR THE HELP AND WHERE MIGHT I FIND THIS SENSOR?
Old Jan 14, 2005 | 09:07 PM
lancer's Avatar
lancer
If you look at the harmonic balancer on the front of the motor its located at about a 10:00(or upper left). I have never changed mine yet but from what i've read there pretty easy. A 10mm bolt holds it in. Once removed it should just pull out. You may have to wiggle it a bit. They say there sometimes tight to get out. Let us know how you make out! P.S You'll have to unplug it first.
