1982 F100
Old Jan 14, 2005 | 06:49 PM
ditchmedic's Avatar
ditchmedic
1982 F100
Have 82 F100 3speed colum, after driving short period of time R front brake begans to pull and heat up. Do you think rebuild would fix.
Old Jan 14, 2005 | 06:53 PM
5_labsownus's Avatar
5_labsownus
Ya, Most likely a rebuild is in order!
Old Jan 14, 2005 | 07:21 PM
DT 466Man's Avatar
DT 466Man
my buddies 82 F150 does the same thing it sits at his dad's farm and never gets used. Shame since it has a brand mew longblock with 1000 miles on it.
Check the rubber hose that goes to the caliper sometimes it swells and lets pressure past it to the caliper but not back. If its not that get a reman caliper.
Old Jan 16, 2005 | 12:36 AM
plowpusher's Avatar
plowpusher
the caliper is probably sticking look a the pads if the one opposit the piston (outerpad) is all worn down the caliper is sticking on the slides take it apart clean the sliding areas on the caliper(top and bottom) clean the caliper mount and the sliding beam and spring bar lube with never sieze as long as your doing one do both old trucks get rusty
Old Jan 18, 2005 | 07:43 AM
ditchmedic's Avatar
ditchmedic
Thanks alot
Ditch
64f100sixcylinder
Feb 11, 2014 12:39 PM
jlang
Jul 13, 2009 12:12 AM
82F100SWB
Jul 27, 2002 06:25 PM
rogerf100
Mar 20, 2002 08:17 PM
fatforty
Nov 11, 2001 08:45 AM
