Bronco II Ford Bronco II
Starting Problem
Old Jan 14, 2005 | 10:42 AM
SaskBroncoII's Avatar
SaskBroncoII
Starting Problem
I have a 1987 Bronco II and I have replaced the starter, starter Solonoid, battery and battery posts and I am still having a problem with starting. When I try and start it sometimes there will be just a click and if I click several times it will eventually turn over. Any ideas why this is happening.
Old Jan 14, 2005 | 02:40 PM
Monty06's Avatar
Monty06
while changing the starting system did you install new positive and negative cables just a though ignition switch malfunction,maybe? maybe blown fuse or a short somewhere did you check your alternator to see if it's charging your battery
maybe your alt is bad .
Old Jan 14, 2005 | 08:16 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
I agree, battery cables/connections.
Old Jan 14, 2005 | 10:18 PM
mrshorty's Avatar
mrshorty
Sounds like what my BII does when the battery terminal isn't making a good connection.
Of course, it also sounds like what my Explorer did when the starter started going.
Old Jan 17, 2005 | 01:12 PM
SaskBroncoII
All good ideas but I already replaced all terminals on the battery. I was told that there is some kind of connection on the steering column that can cause problems when you turn the key. I have to investigate this, has anyone heard of this problem before
Old Jan 17, 2005 | 02:16 PM
Monty06's Avatar
Monty06
it might be your ignition switch gone bad.
