Sponsored by: Auxito
Which shift kit to get?
Old Jan 14, 2005 | 06:14 AM
Fordtrucktexan's Avatar
Fordtrucktexan
These two appear on eBay quite often... I can afford both, but the the more expensive one says on the box "For professional use only" - I can only assume this means not good for the daily driver? What do you experts think about this?
$45 kit Transgo
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
$88 kit
Old Jan 14, 2005 | 11:06 AM
superrangerman2002's Avatar
superrangerman2002
I looked at doing this mod quite extensively awhile ago, but I opted for a tuner instead...but if I were to do this mod, I'd definately go with the bottom one.
Old Jan 14, 2005 | 01:03 PM
Fordtrucktexan
What reasons would you choose the $88 kit over the $45?
Old Jan 14, 2005 | 11:31 PM
Racerguy's Avatar
Racerguy
I wonder if there are any real advantages to installing a shift kit instead of just changing settings with a tuner? Other than price I guess.
The "for professional use only" kit might not come with as good of instructions as a kit made for "non professionals". They might assume that a professional would know what valve is what etc.
Old Jan 14, 2005 | 11:42 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I've always heard that when you change the settings with a tuner that you are just more or less turning up the line pressure on the tranny and that can be a little harder on the transmissions compared to a shift kit.
I have the transgo kit on my truck and love it. Shifts are firm but not to firm. I'm not sure really what the differances are between the two kits but I would opt to go with the second one. It probably comes with all the drill bits and stuff you need. My Kit had a video with that helped out a bunch with the install. The Transgo has a few more parts than most shift kits but it is a much better kit than the rest. IMO
***EDIT*** The first kit doesn't look like it comes with gaskeats from what I can tell. ???
Old Jan 14, 2005 | 11:56 PM
Fordtrucktexan
Aight... I'm buying the $88 kit now. Will let ya'll know what I get in my kit.
