360 engine help
Old Jan 14, 2005 | 02:26 AM
artl666's Avatar
artl666
Unhappy 360 engine help
i recently puchased a 1970 ford f-100 sport custom long box for $400. the truck has been sitting for about a year so i need some tips on what to do to the engine so that it isn't hurt any when i go to run it. any help would be greatly appreaceated
Old Jan 14, 2005 | 07:53 AM
Freightrain's Avatar
Freightrain
This has been covered pretty well in the past. You might want to do a "search" and do make some time for ALOT of reading..LOL!!
If not, the basics: Does it turn over easy? Pull coil wire and crank til you get some oil pressure(changing oil/filter would be a good start). Does it have a full tank of bad gas? Drain and fill with clean new gas. Might want to change fuel filter(if it has the one mounted to fuel pump). Pour some gas in carb and try to start. If plugs/wires/cap/rotor/points in poor shape you might want to replace them too, it depends on how much you plan on using truck.
I think I covered most of the big items. Good Luck.
Old Jan 14, 2005 | 09:52 AM
Mike G's Avatar
Mike G
If it was running when it was parked, it'll run now. Do the basic stuff like Larry suggested, cranking it without the coil will also prime your oiling system, which is key. Don't forget to do an oil change up front too. I had a similar situation and after she was up and running for about a 100 miles, I did another quick oil change, just for grins (and it only costs $10).
--Mike
Old Jan 14, 2005 | 12:08 PM
rusty70f100's Avatar
rusty70f100
Here's what I did when I pulled my old 360 out of storage:
1. Change oil / filters. ALL the filters.
2. New points / condensor / cap / rotor / plugs / plug wires. Set plug gap to .035", and point dwell to about 28 degrees. Before you fire it up the first time set the point gap to .017" with a feeler gauge.
3. Squirt some oil down each cylinder while you have the spark plugs out. A couple shots from an oil can should work ok.
4. If it doesn't run right after you fire it up rebuild the carburetor. I would anyway just to get the varnish out. Mine was sitting longer than yours, but it was completely filled up with scale and other junk. Oh the barnacles...
5. Fire it up.
