ok, can't seem to do a search right now because of server load, so...
How does one remove the headlamps from a '93 ranger? I'm wanting to clean the inside of the lens with Meguiar's Plastix, but can't seem the get the assembly out?! Only reason why I'm even attempting this is because my driver's side headlight blew tonight and I figured I might as well clean the assembly since I have to change bulbs.
Most people clean the outside as this is where the dull plastic is. They are rather well sealed and I'd be surprised if there was dirt in there, unless of course, you had a seal problem. If you do a search, there have been a handful of posts on cleaning the headlamps.
