flywheel ?
Old Oct 2, 2002 | 05:57 PM
Ziimo's Avatar
Ziimo
flywheel ?
will the flywheel off a 300 inline 6 from an 86 f150 fit on a 78 302?
Old Oct 2, 2002 | 07:56 PM
Franklin2's Avatar
Franklin2
flywheel ?
No. Make sure you get an 82 or earlier flywheel for the 78 motor.
Old Oct 7, 2002 | 08:23 PM
serian's Avatar
serian
flywheel ?
>a 78 302?
The bolt holes will line up, and it is the same diameter
but the 300 flywheel will not be the proper balance for
your 302. Your 1978 302 needs a flywheel for an early 302
or 351W with the 28 oz. balance.
The OEM part number is:
D7TE-6375-GA (got one in my garage!)
There is also a newer part number for this flywheel ...
E8??-6375-??
but a dealership or parts store should be able to
cross reference it for you.
Old Oct 7, 2002 | 11:42 PM
canadianfordman's Avatar
canadianfordman
flywheel ?
Bronco2Mudder
May 25, 2002 01:39 PM
slikness
Apr 22, 2002 09:24 PM
rwjr
Jul 26, 2001 08:19 PM
billyb
Apr 28, 2001 09:50 PM
otto
Mar 5, 2001 06:44 AM
