Aerostar Ford Aerostar
Steering Rack Change...
Old Jan 13, 2005 | 08:23 PM
agelder's Avatar
agelder
Any tips? Looks fairly straightforward in the book, but figured I'd check.
Old Jan 14, 2005 | 01:12 AM
copper_90680's Avatar
copper_90680
Depends. 2WD is a 1-hour affair. 4WD is a 1-week affair, if you work really hard.
Old Jan 14, 2005 | 10:51 AM
bertha66's Avatar
bertha66
When I did mine I did not have the book and when I looked at the rack from the front I was thinking that it was bolted into the frame. Well only after braking off my wrench trying to brake the bolt loose did I find the nut on the back side of the crossmember. Also as you replace the rack don't forget the tierod ends. I replaced the pump and hoses at the same time so there would be no used oil in the system.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
