wipers keep stopping
Old Oct 9, 2002 | 07:59 PM
noyozoid's Avatar
noyozoid
Post wipers keep stopping
The wipers on my truck keep stopiing for no reason. They wipe for a short period of time but as soon as they have a little resistance ( rain decreses) they stop. The wiper motor is new on it. Could it be the switch itself or a problem in the wiring.
Old Oct 9, 2002 | 08:07 PM
restorit's Avatar
restorit
Could be the switch, however, I'd suspect the ground wire under the dash. Mine did the same thing after I had the dash apart. As it turns out, I'd forgotten to reconnect a ground wire (with terminal) located fairly close to the switch and screwed to the lower metal frame along the bottom edge of the dash. You may want to check that..... maybe yours is loose.
Old Oct 9, 2002 | 09:39 PM
fishingboy's Avatar
fishingboy
