Sponsored by: Real Truck
will these gears work?
Old Jan 13, 2005 | 04:26 PM
1badSD's Avatar
1badSD
Red face will these gears work?
I found a good deal on a set of 4.56 gears and was wonder if this is what I need for my truck. My truck is an 01 sd cc with a 6in. lift running 37 in. tires. All I know is when I drive my friends truck thats stock that it has a not more pickup than mine. Will these gears give me back that ooomph and not kill the gas milage that much. Thanks in Advance
Old Jan 13, 2005 | 05:22 PM
beemr's Avatar
beemr
Is your truck a 4x4? If so, you will need gears for the front. Otherwise, these gears will help you out. I haven't calculated, but my guess is these will put you around 1800 rpm @ 70 mph. You can do a search here for the formula to check this.
