I HAVE SOME oil problems
Old Jan 13, 2005 | 03:01 PM
DT 466Man's Avatar
DT 466Man
Ok i was on my way to school this morning and i get off the interstate and i look at the oil pressure
It had dropped off the guage.
But it was not clacking like the lifters didn't have pressure so i decided to drive it the rest of the way to school
It was raining hard so i didn't want to get wet.
I hit a bump and it jumped back up
On the way home it did the same thing but about a mile from home no noises so i kept driving it.
Pulled in the driveway and i shut it off
I got out and messed with the wire that was on the sender and the nipple that the sender was connected to was wiggly so i messed with it and i started the truck and it had good oil pressure.
I have a good mechanical guage i want to put in there what size tee do i need?
If you really loose pressure wouldn't the lifters start clacking?
Old Jan 13, 2005 | 11:15 PM
bigbrown84truck's Avatar
bigbrown84truck
it sounds like you need to fix the connection on the oil pressure sending unit. it doesn't matter what gauge is in the truck, as long as that unit doesn't have a good connection ur gonna keep having problems. also i would say at interstate speeds a dry engine would make at the very least strong ticking noises.
Old Jan 14, 2005 | 02:49 PM
DT 466Man's Avatar
DT 466Man
well i got my mechanical guage in and here are the readings
cold idle:40psi
hot idle:18 psi
hot cruise:40psi
cold cruise:40 psi
also i have to replace my rear main in a few weeks
Do those pressures sound right?
Old Jan 14, 2005 | 02:57 PM
DT 466Man's Avatar
DT 466Man
oh and thats the pressure i have with it being time to change my oil.
When i change my oil and have a new filter on it the pressure should go up abit right?
Old Jan 15, 2005 | 08:59 PM
tlindemann's Avatar
tlindemann
Those pressures sound good to me. I have a 81 w/ a 300 and the stock sending unit wires were loose and read funny readings. Put a mechanical guage in and reads 50 lbs cold idle. 15 hot idle and 50 lbs hot cruising down the road. your engine is fine, if you had no oil pressure you would be hearing more the a lifter tapping you would be hearing tires squeeling from a locked up motor. The spot the electric sending unit screws into is 1/8 regular pipe tread I believe
Old Jan 16, 2005 | 10:50 AM
DT 466Man's Avatar
DT 466Man
alright thanks
Old Jan 17, 2005 | 07:17 PM
OLD RED 82's Avatar
OLD RED 82
my 82 f100 has showed no oil pressure since the day i bought her, i dont let it bother me untill it starts clicking
Old Jan 17, 2005 | 07:21 PM
DT 466Man's Avatar
DT 466Man
ok
i have a new development the truck now sounds like an old cornbinder Mediumduty Gas powered truck. my shiney muffler has a hole in it about 3" and i might leave it that way cause it sounds good. Real Deep like a big gas MD
Diesel Submariner
39
Aug 7, 2015 01:11 PM
jbsman0048
1978 - 1996 Big Bronco
Jun 2, 2015 06:24 PM
Redneckfordf2502002
May 19, 2015 10:05 PM
muscletruck7379
15
Nov 18, 2014 06:50 PM
Eduardo Castro
Dec 13, 2013 02:07 PM
