No Power after warm, please help!!!
Old Jan 12, 2005 | 07:05 PM
tkbbn's Avatar
tkbbn
Post No Power after warm, please help!!!
Have a 94 powerstroke diesel with 170,000 miles. Runs and starts great until it warms up (about 5 miles) and then it runs real well as long as the rpms stay above 1200 but if they fall below this it won't hardly rev back up over this. You can press the pedal all the way down but barely builds rpms until 1200 and then revs up great and runs fine. Up to this point I have replaced the fuel filter, changed the oil, replaced the ipr seals, disconnected the ebpv, cleaned out the screen filter on the side of the fuel bowl(did find some small pieces of rubber material) all of this did not make any difference. Talked to a Ford service technician and he said that it was probably the injector o-rings. I thought that this would cause my fuel to be black but my fuel is clean. Any ideas would be greatly appreciated. Also do you think it could be a turbo problem. Thank You for reading this tkbbn.
