fireing problem
Old Jan 12, 2005 | 06:18 PM
olbud's Avatar
olbud
Angry fireing problem
hello every one i put a 72 cab and bed on a77 f250 4x4. i used the electronic ig. box off the 77 the truck will run fine until you cut it off .then it will not start it was not to bad to start with it would allys start untill a few minutes ago i have changed every thing on it you can pull the coil wire off it will spark when you turn the key on and spark when you cut it off but it will not fire when the motor turns over ihave a hot wire comeing from the switch to the electric box and a hot wire from the battery to the coil. it will run fine then just quit going down the road thank for help
Old Jan 12, 2005 | 09:38 PM
Jimbare's Avatar
Jimbare
all alone in the world
sounds like the stator is out to me, does it start after it cools off?
Old Jan 13, 2005 | 03:53 PM
olbud's Avatar
olbud
yes it will. hate to ask a stupid question is stator in the distributor? thank you sir
