No Start Normal Crank... DTC1298... please help
Old Jan 12, 2005 | 02:23 PM
LadyMechanic's Avatar
LadyMechanic
Hello all...
I have a 1999 SuperDuty F450 Diesel that won't start. Getting an allegedly "false" error code of P1298. Replaced IDM and still not starting. It only starts when spraying WD40 into injector... other than that... zilch.
Any leads on this one?
Thanks soooo much.
Old Jan 12, 2005 | 03:24 PM
wlihntr's Avatar
wlihntr
p1298= internal IDM (injector driver module) failure.
Old Jan 12, 2005 | 03:35 PM
mech2161's Avatar
mech2161
On my AllData system I can only pull up a 350. What I'm seeing leads me to an IDM relay. I 'm trying to find an exact location.
Old Jan 12, 2005 | 03:38 PM
mech2161's Avatar
mech2161
#27 Power Distribution box.
Old Jan 12, 2005 | 03:40 PM
wlihntr's Avatar
wlihntr
under hood fuse box relay #32 (injector driver module power relay)
#27 injector driver module fuse 30amp maxi
Old Jan 13, 2005 | 07:32 AM
LadyMechanic
...still working on it... nothing yet
I appreciate your help, but the P1298 is reported to be a false code. A bulleting posted reports this:
"Issue: The Malfunction Indicator Lamp (MIL) may illuminate with a false Diagnostic Trouble Code (DTC) P1298 (Injector Drive Module (IDM) failure). This may be due to circuit tolerance in the IDM setting DTC P1298 if the battery voltage is low. Vehicle or IDM performance is not affected by this false DTC."
I will try the other ideas and report back to you all... thanks so much!
Old Jan 13, 2005 | 08:35 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Your DTC not withstanding....That sounds like a bad glow plug relay, or bad glow plugs, or weak batteries. Will it start on it's own if you plug it in for a few hours?
If the IDM were actually bad it would not run at all. Have you checked the wiring harness at the IDM, PCM and valvecovers to make sure everything is tight and corrosion free?
Old Jan 13, 2005 | 08:43 PM
dixietow's Avatar
dixietow
open fuel filter is seperator full? been having fuel pump problems location under rear door on chassis.9 powerstrokes runin24-7 iff not full a quick way to checcck pump have someone turn on ign. with fuel filter out on dr. side of seperator is fuel inlet it will flow out and everywhere else somtimes after cranking for a while comp. spits out that code due to voltage drop
