DPFE Sensor?
Old Jan 11, 2005 | 09:29 PM
Jeremyshane's Avatar
Jeremyshane
Exclamation DPFE Sensor?
I have a CEL on. I read the code and it's "EGR flow insufficient". I've done some reading and decided to replace the DPFE sensor first. My question is will a faulty sensor make my truck run slightly rough at times, sort of acts like it's got bad gas in it, but I know it doesnt. I fill up with Chevron or Texaco each time and I run Injector cleaner through at each oil change. I have a 2001 Ford Ranger XLT Supercab with 91,000 miles. Thanks in advance for any help.
Old Jan 11, 2005 | 10:42 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
The DPFE sensor helps control the opening and shutting of the EGR valve, and the EGR valve diverts exhaust gas back into the intake and cylinders to be burned. The computer adjusts the fuel injection pulse times based on what it expects the EGR valve to be doing in order to maintain the proper air/fuel ratio. If the EGR system is malfunctioning, it won't be doing things the computer expects it to be doing, which makes for fuel (and possibly timing) adjustments that are not appropriate for actual conditions.
In other words, yes it's possible that a bad DPFE sensor can be a cause of a rough running condition.
Old Jan 12, 2005 | 06:31 AM
Jeremyshane
Thanks again for the information. This site is awesome.
Old Jan 13, 2005 | 03:11 PM
AlfredB1979's Avatar
AlfredB1979
I would have checked the hoses running from the DPFE and the EGR tube among other things the Haynes mentions (being as I've dealt with the code in the last month) before spending $75 on a sensor, but hopefully you've spent the money wisely, and the "cheap fixes first" thing won't haunt you.
Good luck.
Old Jul 12, 2005 | 11:24 AM
propellerhead's Avatar
propellerhead
I replaced the EGR Valve first. It was only $24. That didn't fix it so I did the DPFE next. That was $42. The 0401 was gone after that. I could've done the DPFE first but the EGR Valve was cheaper.
Old Feb 16, 2006 | 08:49 PM
99Blue3.0Ranger's Avatar
99Blue3.0Ranger
Originally Posted by Rockledge
Welcome to FTE!
Thank you Rockledge!! You saved me some dough on this exact same problem! Thank goodness when I was searching for answers, I found this site and a previous post of yours on this same topic!!
Great Site!!
Old Feb 17, 2006 | 07:01 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome 99Blue to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
SteelHorse4x4
Apr 9, 2017 12:12 AM
jprix
17
Dec 3, 2015 07:18 PM
carlakally
New Member Introductions
Apr 23, 2013 03:19 PM
deejdeej
1983 - 2012 Ranger & B-Series
Jun 10, 2010 09:51 PM
Bob Ayers
3.0L V6
Nov 19, 2003 08:27 AM
