Starting project.... need suggestions
Old Jan 11, 2005 | 09:15 PM
BigBuck's Avatar
BigBuck
I am just about to begin a restoration project and judging by the posts on this site, there is a lot of knowlege and experience here. I am interested in any suggestions or comments.
My project is a 1969 f100 my father bought new. I drove the truck through high school and college, but the truck has basically been idle since 1991. It is a stripped F100 short bed. 240 six cylinder 250,000 miles (rebuilt once), 3 speed column shift.
My goal is to refurbish and improve the truck for Sunday afternoon and Friday nite cruises. I will do an engine swap. Right now I have a 460 C6 combo, but I am unsure if I want that much motor... I know, I know, " you can't have too much motor" , but I want a good combo for 2 hour drives as well as short sprints.
I would appreciate any suggestions, links to part suppliers, things to watch out for, money, encouragement, etc.
I will post pictures as I begin this project. Thanks for the help.
Old Jan 11, 2005 | 11:49 PM
1972ford_f-100's Avatar
1972ford_f-100
well,throw that big engine in there,shine it up and do all the engine work and accesories well its out,cuz even though the trucks are huge,u aint gonna have all that room when its in there,throw a four link in the rear and lower it down alittle,if u have the right set up u will kick every one at the track or the street
Old Jan 12, 2005 | 12:17 AM
Fomoko1's Avatar
Fomoko1
Welcome, glad to have you aboard! The possiblies with these trucks are endless, small or big block. Depends on how much driving you do and how fast you want to go thru fuel. If the six is worn out then find a donor vehicle with a 302 power train and everything will be there for a complete swap. I like my 69/302 that has a little more power than a six but still is afordable to drive. Hang on to the 460 in case you just have to have more power later on .Easy to swap that in using stock mounts from 75 up F150 as most of the 73 up parts will work in your truck. have fun and keep us posted.
Old Jan 12, 2005 | 07:25 AM
jowilker's Avatar
jowilker
John, Welcome to FTE You have arrived at the #1 Ford truck site on the web.
Since you have the truck already, you kinda know where you want to go with it. Make a plan. What will you use it for? Will you tow with it or just want to use it for a cruiser? Do you want to modernize it with disc brakes and power steering? What about the finish? I don't recommend a off frame restoration, because a lot good trucks die that way. It is easy to tear one down but all required to put it back is a very long and drawn out affair.
Know what you are gonna do before you jump in, you'll be happy in the long run.
John
Old Jan 12, 2005 | 09:52 AM
garsten's Avatar
garsten
L&L Products and Jeff's Bronco Graveyard are good sites for ford engine swaps and aftermarket parts.
doesn't sound like you want a race truck, so you may think about a 5.0L roller block with a C4. plenty of both @ salvage yards and less expensive than big block parts. converting to fuel injection requires quite a bit of work with the fuel system and a complete harness and computer and the Probst book on ford fuel injection is highly recommended. there are plenty of intake and carb choices for the 5.0L and they have plenty of power for what you described.
if the 460 you have has a rear sump oil pan you are in good shape there...the front sump pans barely fit and make oil changes less enjoyable as the drain plug is over the front cross member.
tempforce
29
Jul 18, 2013 06:18 PM
Mr.F100
21
Feb 20, 2013 07:32 AM
mxd528
Canadian National Chapter
Jun 1, 2008 08:43 PM
460_f100_dude
General Automotive Discussion
Mar 19, 2004 07:21 AM
malloc
New Member Introductions
Jan 30, 2004 09:01 PM
