Help! what did i do?
Old Jan 11, 2005 | 02:42 PM
bocephus_3349's Avatar
bocephus_3349
Question Help! what did i do?
the other day i decided to take the steering shaft out of my truck (1966 f-100 4x4) to clean and lube it all up good. well when i put it back in the steering wheel is now seperated from the base by like a inch or so. so i push it back down and it wont go all the way. now theres play in it. like its not engaged. it kind of feels like its not lining up, but i cant tell. so what do i do now. do i need to tear the whole colum apart now? please help.
Old Jan 11, 2005 | 04:19 PM
bertha66's Avatar
bertha66
Did you try taking the housing lose under the dash and pull it up to meet the wheel?
Old Jan 11, 2005 | 06:23 PM
bocephus_3349
well the problem is that like inside the collum is a 2 piece unit thats come undone. like it wont match up. i have no play under the dash. its only in the actual steering shaft.
Old Jan 11, 2005 | 07:56 PM
barry's Avatar
barry
Did you pull down the inner shift tube? It may have come apart. Can you shift thru the gears? I'm assuming it's a 3 speed column shift. You may have to pull the whole thing out again and re-assemble it on a bench.
Barry
Old Jan 12, 2005 | 08:20 AM
William's Avatar
William
Pull it out! This is bench work and you really need to check that lower bearing! Eyeball the rag joint as well and check it for continuity or the horn may not work. Be careful with the rubber collar these are hard and brittle and will fail. Replacements are available.
Old Jan 12, 2005 | 09:06 AM
bocephus_3349
thanks for the info. but it doesnt have the rag joint its has a u-joint. and its a 4 speed 435 np not a auto. another question is if i have all the bolts and the retaining ring off the shaft on the engine side shoulnt i be able just pull the whole thing out from the cab side? looks like i created a mess. thing that sucks is its my daily drive so im hurting now. also any idea on where to find a seal for the end the connects to the gear box? or am i going to have to go yard hunting.
Old Jan 12, 2005 | 09:45 AM
William's Avatar
William
You have the simplest Ford column. I think the bearing and shaft have become separated at the bottom? There is a spring in the bottom of the column that holds pressure on the shaft. Sorry to say but this is a bench job and you may need a lower bearing. With the firewall cover and clamp removed and the two dash collar bolts out the column should slide out through the cab. The wiring harness has a connector down by the brake pedal (take your time these are easily broken). Be careful and you may be able to save the rubber boot or at least not damage it so badly that you cant patch it.
Old Jan 12, 2005 | 01:33 PM
bocephus_3349
hey thankx william i will try that this weekend. have to wait untill all the snow melts. like idiot i made the truck so big it doesnt fit in the garage all the way. Stupid things rednecks do.
RedDevil460
28
Jan 4, 2014 09:47 AM
tigs1977
Oct 6, 2013 03:40 PM
Snowseeker
Jun 20, 2012 09:32 PM
4.0 Beast
Nov 16, 2008 03:04 PM
DMEMONT
1978 - 1996 Big Bronco
May 31, 2004 05:01 PM
