Timing position help
Old Jan 11, 2005 | 02:08 PM
l1vew1re25's Avatar
l1vew1re25
Question Timing position help
I have recently rebuilt my 2.0L 4cyl. engine in my 1987 2wd ranger and i replaced the cam and all timing components and i did not make the positions on the crank and the cam and i need to know where to position them in order to put on the belt and have the correct timind position. Any help would be appricarted.
Old Jan 11, 2005 | 05:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
See you on the boards.
Old Jan 11, 2005 | 10:22 PM
hreed's Avatar
hreed
The camshaft sprocket should have a mark on it which aligns with a pointer on the engine case. The crank gear should line up with The TDC mark on the belt cover. Make sure both are in the right place with the belt installed before cranking the engine.
Old Jan 12, 2005 | 01:12 PM
l1vew1re25's Avatar
l1vew1re25
Question still could use some help
i have located the marks on both gears and the mark to line the crank up to. But i can not find a pointer or a mark on the block or head to line up the cam gvear with. isn't there a way to set it up by the position of the valves?
Old Jan 12, 2005 | 02:13 PM
cruster's Avatar
cruster
Not sure about yours but on my 1991, there is a mark for the camshaft not on the block itself but on the rear half of the timing belt cover. When the crankshaft was at TDC, the camshaft was pointing at approximately 5 o'clock.
