AWD Problems
Old Jan 11, 2005 | 09:56 AM
ItsJustMe's Avatar
ItsJustMe
AWD Problems
I have a 1998 AWD Explorer and it appears that the AWD system is not working at all. Does anyone have any ideas as to what may be causing this problem? Any help would be GREATLY appreciated!
Old Jan 11, 2005 | 04:15 PM
Ponyracer's Avatar
Ponyracer
What are the concerns that point you in that direction?
Old Jan 11, 2005 | 04:27 PM
ItsJustMe's Avatar
ItsJustMe
Hello Jim,
When in snow, the rear wheels will spin and not the front. This happens when just taking off or when moving and you step on the gas pedal. You can also feel the back end start to come around. Before, you could step on it and it would track relatively straight in slippery conditions.
Dale
Old Jan 11, 2005 | 04:53 PM
Ponyracer's Avatar
Ponyracer
I would go and have it check for codes. The manual has a tech starting with tests with their equipment checking pids in the computer and modules. you could check the fuses and see if any are burnt out. #'s 4, 6, 9, 10, 20, 26, 28 pull one at a time and reinstall if ok.
Old Jan 11, 2005 | 07:48 PM
ItsJustMe's Avatar
ItsJustMe
Thanks for the info. Jim. I'll check the fuses first and go from there.
Dale
Old Jan 12, 2005 | 12:11 AM
Ponyracer's Avatar
Ponyracer
No problem, let me know if there is anything else you need.
Old Jan 12, 2005 | 09:06 AM
ItsJustMe's Avatar
ItsJustMe
The fuses are ok Jim. I see that there is a relay for the transfer case. I am going to check that out next. Thanks!
Dale
Fordboy49
Aerostar
26
Nov 25, 2016 01:27 PM
WhoKnows
Feb 16, 2008 12:10 AM
Recycleking
Aerostar
Jul 23, 2007 03:50 PM
amkazen
Sep 3, 2005 02:17 PM
dlabrie
Sep 5, 2000 03:37 PM
