fuel filter(s)
Old Jan 11, 2005 | 08:17 AM
steelman 1999's Avatar
steelman 1999
fuel filter(s)
could someone who knows for sure tell me how many fuel filters an 05 F-250 6.0 has? thak you for the info
Old Jan 11, 2005 | 08:32 AM
lpbaca's Avatar
lpbaca
There are two one on the engine and one below the drivers side on the frame. Refer to your owners manual. You might want to check out this site for fuel filters www.oilguard.com excellent prices. Beats the automotive shops.
Old Jan 11, 2005 | 10:18 AM
steelman 1999
filters
thanks very much for your information on the filters. just ordered, and they are much less expensive than i can buy local. plus, free shipping!!
Old Jan 11, 2005 | 11:38 AM
Daryl Hunter's Avatar
Daryl Hunter
Hi steelman 1999,
Welcome to the 6.0 L forum and to FTE. Please take a moment to review the Welcome sticky post at the top of the forum page. There are links to great threads and other info in there.
Old Jan 12, 2005 | 10:07 PM
hank-n-mo's Avatar
hank-n-mo
I am not mechanically inclined, but I can follow good instuctions. I change the fuel filter on my wife's 7.3L, but haven't tried to change on my 05 6.0. I bought a 36mm socket to work on the horizontal fule filter and have drained the water out of the horizontal filter. I understand there is a notch on the filter and I want to make sure I do it correctly. Do I change both filters before cranking or do I change one first and then the other? A good set of instructions would really help.
Thanks in advance
Old Jan 12, 2005 | 10:59 PM
Super Steve's Avatar
Super Steve
I believe there are instructions at the top in the tech file somewhere. And yes, you change both before cranking, but before cranking, turn the ignition on and off a few times for 15 second intervals to let the fuel pump do it's job. Then it should fire right up.
Old Jan 12, 2005 | 11:31 PM
guydiver12's Avatar
guydiver12
When I changed my fuel filter on the motor, the sump was still full of fuel. I just put the new one back down in there and screwed the cap on. The horizontal was dry because I drained it through the drain hole before pulling the cap. Didn't know to cycle the key. Just started like normal. No problems, no leaks, no dealer profits
Old Jan 13, 2005 | 07:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Thanks in advance
Welcome to the only family Ford Truck site, on the net. The members in this forum are very knowledgeable about these engines; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help to understand more about FTE and how it operates.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read...if you like trucks
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
Your instructions are here
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Old Jan 13, 2005 | 05:57 PM
hank-n-mo's Avatar
hank-n-mo
I could not find any instructions for the 6.0 fuel filters. Any help would be appreciated.
Old Jan 13, 2005 | 10:50 PM
Super Steve
Click on the 6th thread from the top, the red one that says "read first", "tech folder". In there are all the different maintenance topics including changing fuel filters.
Someone was nice enough to organize all those in there for everybody.
Old Jan 14, 2005 | 05:25 PM
hank-n-mo's Avatar
hank-n-mo
Thanks! I found it. I am new to this forum, but am getting the hang of it. Seems like there is a ton of good information.
Thanks again.
