Oil & Lubrication
transmission fluid change
Old Jan 11, 2005 | 12:31 AM
ford390gashog's Avatar
ford390gashog
i am going to need to change the fluid in my 2003 ford expy but i wanted to know if using a fluid made for use where mercon fluid is used would this work alright i think the tranny says mercon IV heres the link http://royalpurple.com/prodsa/matfa.html
Old Jan 11, 2005 | 07:33 AM
cmlind's Avatar
cmlind
If your owners manual or dipstick says to use Mercon, this oil would be fine since it is Mercon rated. Just make sure that it is mercon and not Mercon V. It is not recommended to interchange them.
Old Jan 11, 2005 | 08:19 AM
Casey's Avatar
Casey
Your transmission requires MERCON V.
