EBP sensor
Old Jan 10, 2005 | 08:52 PM
03250stroke's Avatar
03250stroke
EBP sensor
What should happen if you unplug the EBP sensor?
Old Jan 10, 2005 | 10:52 PM
SBV45's Avatar
SBV45
The PCMs programming is set to use default values if any sensor is "out of range". The impact would be that you don't get full performance of the VGT actuator and turbo performance. The idea of the variable vanes is to give you low end turbo performance by closing the vanes with low exhaust back pressure to focus the exhaust onto the turbine wheels. Think if a pistol grip garden hose nozzle that you get a stronger stream of water by squeezing the grip closed. Similar concept. Then when the engine picks up speed and subsequent exhaust back pressure, the vanes open and take full advantage of the greater volume of exhaust.
Go to http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html and read the section on VGT in the Air Management System.
Old Jan 11, 2005 | 07:07 AM
03250stroke
Well I unpluged mine and my truck no longer stumbles or surges and seems to run stronger? Anyt ideas?
Old Jan 11, 2005 | 07:32 AM
4x4Mark's Avatar
4x4Mark
It may have been bad, providing improper readings. Now, its running off of the default values.
Old Jan 11, 2005 | 07:48 AM
SBV45's Avatar
SBV45
Depending on your engine year, they used different EBP sensors from what I understand. I read a post where there is a replacement sensor for the one that doesn't work so well.
Good catch, 4x4Mark, I would agree with that. I read someone refer to the default values as "limp mode". I wouldn't call it that.
Old Jan 11, 2005 | 08:35 AM
lpbaca's Avatar
lpbaca
Ford is currently working on an upgrade for the EBP sensor. Apparently the current ones have issues failing or faulting out. The only fix as of now is to replace it. I found out this information on this site from a previous post.
