Problem Over/Drive light flashing
Old Jan 10, 2005 | 04:00 PM
zomowiec's Avatar
zomowiec
Problem Over/Drive light flashing/ code 0500
Could somebody help me to indentify this problem, I was driving for about 20miles than i turned off my engine for a minute or two and restarted again and my O/D light was flashing and my speedo didn't work, also SES light came on with code 0500, after i restart my engine again it was all normal again
This happened to me couple of times allready i have checked my trans fluid level and it was good
By the way my car is 00 Excursion Diesel Thanks for help
Old Jan 10, 2005 | 06:48 PM
ExpySport's Avatar
ExpySport
I had the same exact thing happen on my 02 Expedition. At first, it was an intermittent flash, then it was a constant flash. Speedo was acting funny and the trans was shifting horribly. Took it to the dealer and they found one of the modules inside the trans to be bad. They replaced it and no more problems. This was 2 years ago.
Old Jan 10, 2005 | 07:48 PM
JWK0721's Avatar
JWK0721
Same Thing Happened To My Brothers 2000 F-350 Diesel. Bad Module Inside The Transmission, Had It Changed And Has Not Had A Problem Since. It Had 70,000 Miles On It When It Happened.
Old Jan 11, 2005 | 12:09 PM
zomowiec's Avatar
zomowiec
Did you guys had any SES codes when this happened and how much did the repair cost
Thanks
Old Jan 11, 2005 | 01:04 PM
rlh68050's Avatar
rlh68050
P0500 = vehicle speed sensor
Old Jan 25, 2005 | 12:40 AM
madvike's Avatar
madvike
I have an 02 w/ 7.3 and mine has done that twice. 10,000 & 48,000 both times it was a module I believe, both times only when I was towing. Ford say's not to worry, but I think it has something to do with the torque converters with the diesel, haven't heard of it happening with the V-10.
Old Jan 25, 2005 | 06:36 AM
lockdoc600's Avatar
lockdoc600
I once had similar issues with a 7.3 PSD in my work cube van. The vehicle was new and this was a very frustrating problem.....O/D lights flashing...the trans shifting whenever it wanted to and not when it should. I was driving 55 and it downshifted to a much lower gear just out of the blue! My problem was even easier.....turned out to be that someone forgot to tighten the grounding cable bolt to the frame when the body was installed! A few turns of the wrench and all of those problems went away forever. Sometimes it is the really simple things in life that frustrate us the most.
Good luck with yours.
endobear
13
Nov 12, 2013 10:28 AM
thinksnow
Apr 20, 2011 05:57 PM
stingerstang
Jun 9, 2004 08:29 AM
mtblocker
Jul 24, 2003 04:20 PM
